Intel® NUCs
12334 Discussions
Intel® NUC Kit NUC6i3SYH CMOS ERROR
RSRAVI2022
Hi Intel won’t help advised me to post on here
Having problems with checksum cmos error on boot up
Done this already no joy
Flashed latest bios
Set to default
Changed the battery cmos one
Makes no difference
Clears the error on bios
But comes back any help would be much appreciated
Only thing I have not tired is jumpers but I don’t think NuC have them
Not done recovery bios either not sure that will make a difference on thank you
n_scott_pearson
Super User Retired Employee
There are a lot of batteries that are designed - backwards - for Dell systems. Compare the colors of the new battery against the old to be sure it is correct.
Hope this helps,
RSRAVI2022
n_scott_pearson
The important question is: Have you have verified that the wire colors are correct? at the connector?
RSRAVI2022
Hello , no I have not unless I remove the plastic cover from the battery to check positive and negative are correct , you would have thought black and red would be standard for bios battery ?
AndrewG_Intel
Hello @RSRAVI2022
We hope that the assistance provided by the community has been helpful.
We would like to inform you that due to the Intel® NUC Kit NUC6i3SYH has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
Note: You might need to search for the proper Product Category and click on its "Show more" link if the product is not visible in the top rows.
Andrew G.
n_scott_pearson
Just look at the colors at the connector; you don't have to worry about the colors being used differently.
'You would have thought..." is an assumption. In the face of something not working, always, always eliminate assumptions; they will screw you up more often than not.
Ok, if the wire colors match the original ordering (and don't follow the Dell backwards ordering), then I can only conclude that the CMOS part is failing. This is not something that you can do anything about; it may mean replacing the unit.
RSRAVI2022
Hello thank you for the info
I be really surprised the unit has gone wrong as once set the the ripen on bios every thing is working fine till I power off from mains then it will lose time only
To be honest am quite shocked at intel support them selfs
Any way I get some electrical conductive tape and make two new batteries see ifs a wiring issue that will eliminate that from the equation
Thank you
LeonWaksman
This video clip may be some help for you: CMOS battery hack
Leon
RSRAVI2022
Hello thanks yes see that video
Ok tired battery both ways still same issue don’t make sense
I have to lever it plugged in now I suppose
n_scott_pearson
That's because your CMOS stayed powered, via the main power supply, until you unplugged it. When you unplugged it, it then drained and lost its contents (including the current date and time).
