Intel® NUCs
12323 Discussions
Intel® NUC Kit NUC6i7KYK audio failure latest driver
PRyan4
Install HD Audio driver failure error code: - 0001 no driver supported with latest driver.
Paul
AlHill
Yes, I get the same error.
What I did is to install the driver manually (using the have disk method).
IDSA still thinks you need the driver but it is installed.
Doc
PRyan4
Hi there
Also tried the manual install and it says the best driver is already installed which is a Microsoft one.
I ended up with the Microsoft one after running the installer first and after reboot.
It removed older driver with Realtek control center as well.
AlHill
Do you know how to do the "have disk" method?
DId you compare the version number installed to the version number that is going to be installed?
Doc
PRyan4
Have disk through device manager, think so.
I had the latest previous realtek driver installed that was previously available on intel skull site.
Downloaded and installed the latest new on that just appeared on skull intel site.
It uninstalled the Realtek driver, and after reboot I ended up with a Microsoft driver. IDSA downloads the same driver and now comes up with error.
In Device manager, I completely uninstall device, reboot and try have disk method and it says lates driver installed which is Microsoft one 10.0.18362.356, no Realtek control center.
AlHill
OK, use the "Have disk" method to install the driver. I did, it works.
Doc
PRyan4
Hmm, got it now with "have disk" but with warning not to.
Shows Realtek in Device Manager, but no Realtek control center.
Dunno why Intel releases drivers like this, like the rigmarole I had to go through to install latest Intel Graphics 7529 for Hades.
Thanks Al.
JLF
Hi
Have the same (...) with this update.
I just choose to reinstall the previous version of the driver and I have my super sound back.
I wonder what this update brings if it isn't even able to install itself properly.
The realtek control center is easy to "reinstall".
In the c:\programs\realtek\audio\HDA folder you can find the RAVCpl64.exe file. Juste create a shortcut on it, and put it in your taskbar.
JLF
AlHill
Why do you not tell us what "(...)" means?
Doc
PRyan4
See it's been pulled from Skull download site but still shows up in IDSA.
AndrewG_Intel
Hello All
We would like to inform you that we have checked the behavior described in this thread and we are currently investigating this and as soon as we have more details we will be posting back in this thread.
In the meantime, you can install the Realtek* High Definition Audio Driver Version: 6.0.1.7982 which we tested on our lab and it should install without problems. This also should stop the update message from Intel® Driver & Support Assistant (Intel® DSA).
https://downloadcenter.intel.com/download/26329/Realtek-High-Definition-Audio-Driver-for-Legacy-Inte...
Andrew G.
AndrewG_Intel
Hello All
We have confirmed that the Realtek* High Definition Audio Driver with error code: - 0001 has been removed from Intel® DSA and from Intel® Download Center and we recommend staying with the current driver 6.0.1.7982.
Thank you for the feedback provided.
Andrew G.
