Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel NUC M.2 expansion capabilities
I bought an Intel NUC5I3RYH and I need some more details on the M.2 connector: normally it is used to host an SSD, but in my case I was wondering if I could use the standard SATA port for the hard disk and, instead, the M.2 connector to host a M.2 capture card to acquire an HDMI input. On the technical datasheet it is reported "Expansion Capabilities: One M.2 connector supporting M.2 2242, M.2 2260, and M.2 2280 (key type M) modules" but no more information are provided.
Is there something in particular I have to do to make this work?
Any suggest will be particularly appreciated.
Thank you very much,
Sandro
Tags (2)
Highlighted
Super User Retired Employee
Re: Intel NUC M.2 expansion capabilities
Sandro,
My understanding is that you can use the PCIe lanes or you can use the SATA lane -- but you cannot use both. You can follow-up with Intel Customer Support if you wish, but this has been asked before and that was the answer.
Sorry,
