Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13500 Discussions
Intel NUC M15 Laptop Blinking Power Button (3 seconds on, 2 seconds off)
jeeshenlee
I bought an Intel NUC M15 laptop recently (less than two months).
Two weeks ago, I started notice the power button blinking continuously.
At first, I thought it's an indicator of battery charging. I tried check the blink codes document, none of the pattern mentioned match what I'm seeing (3 seconds on, 2 seconds off). Here's the video recorded.
Any idea? Should I be worried?
NOTE: I'm using the latest BIOS, version 0069
LeonWaksman
Is the Power LED solid ON when the laptop is disconnected from AC Power? According to User Guide, page 6 (G), the Power Button is White Breathing when connected to AC and Battery is charging.
Leon
LeonWaksman
Leon
jeeshenlee
@LeonWaksman , thanks for pointing that out!
I was referring to this doc which does not mention the White Breathing indicator.
DeividA_Intel
Hello jeeshenlee,
In this case, the article "Blink Codes and Beep Codes for Intel® NUC" is meant mostly for our NUC products and not for the Laptop kit products (Intel® NUC M15 Laptop Kit).
As LeonWaksman mentioned, the information for the unit can be found in the user guide. Also, I recommend you to check with the place of purchase for extra support in case that you need spare parts or get a replacement.
Deivid A.
