I'm a owner of a M15 brazilian laptop variant and i'm facing an issue since I aquired the laptop. after a windows 10 instalation, the speaker sound stops to work after the first OS restart. there are no hardware or driver problems apparently., the headphone jack works without a problem.
Contacting the laptop vendor, they send me an executable that locks and unlocks the bios. when I execute the lock or unlock, the sound returns until I turn off the laptop or restart the windows. this is not a viable solution due the fact that I need to execute this bios file every time that I need speaker sound.
bios executable to lock and unlock...
I tried for many times, reinstall the OS with fresh version, tried windows 11 and the problem persists.
my laptop data, retrieved by intel driver's assistant:
Intel® Driver & Support Assistant
Detailed Report
Last scan: 13/04/2022 12:29
Computador (Computer)
Avell High Performance B.ON
Fabricante do sistema (System Manufacturer) Avell High Performance
Modelo do sistema (System Model) B.ON
Tipo de sistema (System Type) Portáteis (Mobile)
Fabricantes da motherboard (Motherboard Manufacturer) Avell High Performance
Placa-mãe (Motherboard Product) Avell High Performance
Versão do BIOS (BIOS Version) BCTGL357.0067.2021.0810.1743
Data (Date) 10/08/2021
Versão do SMBIOS (SMBIOS Version) 3.3
Inicialização segura (Secure Boot) Desligado (Off)
Sistema operacional (Operating System)
Microsoft Windows 10 Pro (64 bits)
Release 2009
Version 21H2
Compilação do sistema operacional (OS Build) 10.0.19044
Construir filial (Build Branch) vb_release
Locale Português (Brasil)
Diretório do Windows (Windows Directory) C:\Windows
Diretório do sistema (System Directory) C:\Windows\system32
Versões do .NET Framework (.NET Framework Versions) 4.0.0.0, 4.8.04084
Navegadores de Internet instalados (Installed Internet Browsers) Mozilla Firefox, Internet Explorer 11.789.19041.0, Microsoft Edge
Processador (Processor)
11th Gen Intel® Core™ i7-1165G7 @ 2.80GHz
Detalhes do dispositivo (Device Details)
Fabricante (Manufacturer) GenuineIntel
Descrição (Description) Intel64 Family 6 Model 140 Stepping 1
Arquitetura (Architecture) x64
Número de núcleos (# of Cores) 4
Nº de threads (# of Threads) 8
Frequência baseada em processador (Processor Base Frequency) 2803 MHz
Tensão atual (Current Voltage) 8.
Cache nível 2 (Level 2 Cache) 5120 Kb
Cache nível 3 (Level 3 Cache) 12288 Kb
ID do processador (Processor Id) 0x806C1
Disponibilidade (Availability) Funcionando com a potência máxima (Running at full power)
Gráficos (Graphics)
Intel® Iris® Xe Graphics
Compatibilidade do adaptador (Adapter Compatibility) Intel Corporation
Processador de vídeo (Video Processor) Intel® Iris® Xe Graphics Family
Resolução (Resolution) 1920 x 1080
Bits por pixel (Bits Per Pixel) 32
Número de cores (Number of Colors) 4294967296
Taxa de atualização - Atual (Refresh Rate - Current) 60 Hz
Taxa de atualização - Máxima (Refresh Rate - Maximum) 60 Hz
Taxa de atualização - Mínima (Refresh Rate - Minimum) 40 Hz
Provedor (Provider) Intel Corporation
Versão (Version) 30.0.101.1191
Data (Date) 12/03/2021
Tipo de DAC do adaptador (Adapter DAC Type) Internal
RAM do adaptador (Adapter RAM) 1,00 GB
Status Este dispositivo está funcionando corretamente. (This device is working properly.)
Localização (Location) PCI bus 0, device 2, function 0
ID do dispositivo (Device Id) PCI\VEN_8086&DEV_9A49&SUBSYS_20978086&REV_01\3&11583659&0&10
Áudio (Audio)
Tecnologia Intel® Smart Sound para microfones digitais
Provedor (Provider) Intel® Corporation
Nome (Name) IntcDMic.sys
Versão (Version) 10.29.0.6815
Data (Date) 22/11/2021
ID do dispositivo (Device Id) INTELAUDIO\CTLR_DEV_A0C8&LINKTYPE_02&DEVTYPE_00&VEN_8086&DEV_AE20&SUBSYS_20978086&REV_0001\5&215CCA83&0&0000
Tecnologia Intel® Smart Sound para áudio USB
Nome (Name) IntcUSB.sys
ID do dispositivo (Device Id) INTELAUDIO\CTLR_DEV_A0C8&LINKTYPE_06&DEVTYPE_06&VEN_8086&DEV_AE50&SUBSYS_20978086&REV_0001\0604
Tecnologia Intel® Smart Sound para áudio MIPI SoundWire®
Nome (Name) IntcSDW.sys
ID do dispositivo (Device Id) INTELAUDIO\CTLR_DEV_A0C8&LINKTYPE_05&DEVTYPE_05&VEN_8086&DEV_AE35&SUBSYS_20978086&REV_0001\5&215CCA83&0&0500
Tecnologia Intel® Smart Sound para áudio Bluetooth®
Nome (Name) IntcBTAu.sys
ID do dispositivo (Device Id) INTELAUDIO\CTLR_DEV_A0C8&LINKTYPE_03&DEVTYPE_00&VEN_8086&DEV_AE30&SUBSYS_20978086&REV_0001\5&215CCA83&0&0000
Rede e E/S (Networking and I/O)
Intel® Wi-Fi 6 AX201 160MHz
Fabricante (Manufacturer) Intel Corporation
Instalado (Installed) True
Endereço MAC (MAC Address) A4:6B:B6:D9:A8:BE
Nome do serviço (Service Name) Netwtw10
Versão (Version) 22.120.1.9
Data (Date) 03/10/2022
ID do dispositivo (Device Id) PCI\VEN_8086&DEV_A0F0&SUBSYS_00748086&REV_20\3&11583659&0&A3
Revisão (Revision) 20
Wintun Userspace Tunnel
Fabricante (Manufacturer) WireGuard LLC
Nome do serviço (Service Name) wintun
Provedor (Provider) WireGuard LLC
Versão (Version) 0.8.0.0
Data (Date) 12/10/2019
ID do dispositivo (Device Id) ROOT\NET\0000
TAP-Windows Adapter V9
Fabricante (Manufacturer) TAP-Windows Provider V9
Endereço MAC (MAC Address) 00:FF:A5:36:77:C4
Nome do serviço (Service Name) tap0901
Provedor (Provider) TAP-Windows Provider V9
Versão (Version) 9.24.6.601
Data (Date) 10/08/2020
ID do dispositivo (Device Id) ROOT\NET\0001
Controlador 1 de Thunderbolt
Versão (Version) 1.41.1229.0
Geração do Thunderbolt™ (Thunderbolt™ Generation) Thunderbolt 4 (9A1B)
Número de portas (Number Of Ports) 1
Versão do firmware NVM (NVM Firmware Version) 41:0
Tunelamento Pcie (Pcie Tunneling) True
Controlador 2 de Thunderbolt
Geração do Thunderbolt™ (Thunderbolt™ Generation) Thunderbolt 4 (9A1D)
Memória (Memory)
16 GB
Memória física - Total (Physical Memory - Total) 16 GB
Memória física - Disponível (Physical Memory - Available) 12,42 GB
Memória virtual - Total (Virtual Memory - Total) 18,05 GB
Memória virtual - Disponível (Virtual Memory - Available) 14,85 GB
Arquivo de página (Page File) C:\pagefile.sys
Espaço de arquivo de página (Page File Space) 2,38 GB
Armazenamento (Storage)
IM2P33F8A-512GD
Capacidade (Capacity) 476,94 GB
Versão (Version) T1103B0L
Número de série (Serial Number) 0000_0000_0000_0000_0000_0000_0000_0001.
Partições (Partitions) 3
Provedor (Provider) Microsoft
Versão (Version) 10.0.19041.789
Data (Date) 21/06/2006
ID do dispositivo (Device Id) SCSI\DISK&VEN_NVME&PROD_IM2P33F8A-512GD\5&2D1646CA&0&000000
caminho do dispositivo (Device Path) \\.\PHYSICALDRIVE0
C:
Sistema de arquivo (File System) NTFS
Compactado (Compressed) False
Capacidade (Capacity) 476,32 GB
Espaço livre (Free Space) 433,25 GB
Intel SSU data attached.
Someone faced or are dealing with this problem?
