Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13513 Discussions
Intel NUC Mini PC Core i7 11th Gen support Widescreen monitor?
Kaz999
Hi
Does anybody know if this will support a 34" or 43" widescreen monitor with a view to extend displays into at least 3?
https://www.mwave.com.au/product/intel-nuc-mini-pc-rnuc11pahi70000-core-i7-11th-gen-16gb-ram-500gb-ssd-w10-home-ac41806
I know nothing about technology and have already returned one system that didn't work.
I've been told that this will run 3 x monitors but the adapter I was sold doesn't work so I'd be limited to only 2 x monitors.  I'm in the process of returning the adapter.
I'm now wondering if it would just be easier to replace the 3 x monitors with 1 x widescreen monitor.
I figure posting on an Intel page I'm more likely to get an accurate answer.
Thank you in advance to anyone who can help me.
Alberto_R_Intel
Kaz999, Thank you for posting in the Intel® Communities Support.
You mention "I've been told that this will run 3 x monitors", that is correct, in fact, it supports 4 displays as you can confirm in the link below under the "Processor Graphics" tab:
https://ark.intel.com/content/www/us/en/ark/products/205073/intel-nuc-11-performance-kit-nuc11pahi7.html
"the adapter I was sold doesn't work so I'd be limited to only 2 x monitors", keep in mind that Intel® recommends the usage of straight connections, for example, an HDMI to HDMI cable, when using adapters or converters they might or might not work as expected and Intel® cannot guarantee they will work as they should:
https://www.intel.com/content/www/us/en/support/articles/000026412/graphics.html
Does anybody know if this will support a 34" or 43" widescreen monitor with a view to extend displays into at least 3? In the following link, you will find the list of monitors and TVs supported by the Intel® NUC 11 Performance kit - NUC11PAHi7, please look for NUC11PAHi7 on the menu on the left-hand side under "Kits", select it and then see under "Monitors" and "Televisions". It is important to mention that if a monitor or TV is not listed in there, it does not mean it is not compatible is just that Intel® have not tested it:
https://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC#
Albert R.
Kaz999
Hi Albert
Thank you so much for your response.  Very much appreciated.
If this NUC is capable of 4 monitors, how do you, in fact, connect without the use of adapters?
Alberto_R_Intel
Hi Kaz999, You are very welcome, thank you very much for your response.
"If this NUC is capable of 4 monitors, how do you, in fact, connect without the use of adapters?", some of them work, is just that we cannot guarantee that all of them will, actually there are some adapters listed on the link provided previously for compatible products of the Intel® NUC.
In the following link, you will find additional details about how you can connect 4 monitors to the Intel® NUC and the resolutions supported by them:
https://www.intel.la/content/www/xl/es/support/articles/000058069/intel-nuc.html
Albert R.
Kaz999
You are a wealth of knowledge Albert!  Thank you so much for your assistance.
All the best and stay well
Karen
Alberto_R_Intel
Hi Kaz999, You are very welcome, thank you very much for your feedback.
"All the best and stay well", you too, we are glad to know the information provided was useful and helpful for this scenario.
Any other inquiries, do not hesitate to contact us again.
Albert R.
