I have an Intel NUC NUC10i5FNH and I am trying to get it to connect to some BLE devices. It can connect and see a bluetooth classic device like my iPhone.
In researching I am unclear on which of two Intel Chipsets is used?
- Intel AX201 which is what the data sheet states
- Intel 9462 which is what Ubuntu hardware shows
If it is the AX201 and the OS is not identifying the card correctly I can follow up on that in the Ubuntu forums.
Can someone confirm if either the AX201 and/or 9462 support the LE stack?
Cheers
I can confirm that the NUC10i5FNH, has AX201 WiFi adapter. You may remove the bottom cover and check by your self. See the attached image.
Leon
Well that is fantastic. One variable removed in the equation. Do you know if the AX201 supports BLE for sure?
Cheers!
Since the Bluetooth in AX201 is specified to BT Version 5.2, it supports BLE. You may read about Supported Bluetooth profiles for BT 5.0 under Windows 10.
Leon
According to the product brief (here: https://www.mouser.com/pdfDocs/wi-fi-6-ax201-module-brief.pdf), BLE is supported.
Hello scurvydog33,
Were you able to check the previous posts?
Steven G.
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
