Community
cancel
Showing results for
Search instead for
Did you mean:
CGree3
Intel NUC NUC7I7BNH: Windows re-size & move to top left of the screen after waking from sleep.
what's going on with this issue please? I have carried out all the suggestions offered by you yet it still persists...
Community Manager
Hello Clivo
We received your thread and I understand that you are having Graphic Display issues (Re-size) after your computer wakes up from sleep.
Please accept our apologies for the inconvenience that this could be causing.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click •Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
I hope to hear from you soon.
Best regards.
Diego S.
CGree3
Hi Diago,
I can't see which box to tick - pls see screenshot. Have enclosed txt file if that helps.
Cliveo
n_scott_pearson
Super User Retired Employee
I would love for Intel to fix this issue. They can then tell NVIDIA how to do so and stop it from happening on my tower PC.
Community Manager
Hello clivo,
Thank you so much for your reply and the information provided.
Based on the report that you attached your BIOS and Graphic Driver(s) seem to be out of date, which could be the reason of the Re-size issue that you are experiencing.
Please go ahead and use the following links in order to update your system and let us know the outcome:
BIOS Update Instructions:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/Express-BIOS-Update-Instruct... https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/Express-BIOS-Update-Instruct...
Latest BIOS: https://downloadmirror.intel.com/27397/eng/BNKBL357.86A.0060.EB.EXE https://downloadmirror.intel.com/27397/eng/BNKBL357.86A.0060.EB.EXE
After that, please make sure that you have the latest Windows 10 Fall Creators Update on you OS.
Then please go ahead and install the latest Graphic Drivers (Manually) by following these instructions:
https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
Latest Graphic drivers: https://downloadcenter.intel.com/download/26947/Intel-HD-Graphics-Driver-for-Windows-10-for-Intel-NU... https://downloadcenter.intel.com/download/26947/Intel-HD-Graphics-Driver-for-Windows-10-for-Intel-NU...
Diego S.
CGree3
Hi Diego,
I've undated the BIOS.
For the graphics I downloaded the zip file. When I went to install the driver, the system advises I've got the best driver already installed.
Please see enclosed.
Clive
Community Manager
Hello Clivo,
Thank you for your response.
I am very glad to hear that you were able to successfully update the BIOS. In this case please go ahead and disregard that message "best driver already installed."
Based on the SSU Report and the screenshots attached, you have the 4877, the latest driver as shared before, is 4901.
Can you please uninstall (manually) the current one (4877) from device manager and give it a try again?
As well, is there a chance for you to perform a clean installation of Windows?
Diego S.
CGree3
Hi Diego,
all of the suggestion carried out, yet the issue still persists!
I'd really rather not do clean installation of Windows again, there's so much I'd need to rebuild...
Clive
Community Manager
Hello EncryptionX,
Thank you for your reply, I really appreciate it.
I understand that reinstalling Windows might be little bit complicated,
While performing further research about your issue, I was able to find the official thread for this specific error, which is under investigation between Microsoft and our management.
Apparently this situation occurs due to an OS design. The OS is not storing and persisting the window size and placement upon the disconnection of some display devices. Our driver is reporting a plug event correctly to the OS, but without persistence windows shift and move to the primary display. Other manufacturers may work around this through their own driver implementations.
At the moment the investigation is on 'hold' while our teams gather more information in order to get the issue fixed.
Here you will find the original thread:
/thread/102871?start=45&tstart=0 https://communities.intel.com/thread/102871?start=45&tstart=0
All the most recent posts will be posted there so I strongly recommend you to post your issue there and to follow the thread in order to get the latest updates about your case.
On the meantime I will send this thread to the team in charge of the investigation, however as shared before, all the relevant answers about the resize will be posted on the original case.
I hope this helps,
Diego S
CGree3
thanks Diego that's been very helpful.
