Just had it happen again after you closed the original topic. Sadly, Windows updates just happen so often and today was the day again.
My SO just booted up her NUC, got greeted by the given screenshot.
Nothing worked except disabling secure boot in the BIOS. As you can see in the report of the old thread, that feature was on and working alright. After disabling it, windows did a restart and after that, it's commonly known 30% updates installed screen show up and completed.
It was not working unattended which is the worst case. I expect the whole system to require a reinstall on the next windows update.
Any further ideas?
This sounds like a bad SSD to me.
Have you tried cleaning the disk with diskpart before reinstalling Windows? You can open a command window with SHIFT+F10 after booting the installation media. Get the drivers from Windows Update only; be sure to check the "optional updates" section as well.
Yes, did a dispart clean on my first installation and always remove all existing parts during windows reinstall.
chkdsk reports no errors, samsung toolkit shows no abnormalities, smart report shows green across the board. I think switching off secure boot should not fix a broken SSD with a windows installation that worked with it prior a windows update.
I can only suggest installing the driver for the NVMe controller from Samsung's support website.
Hello NucNotUp,
We will complete further research about your issue, and we will update this thread as soon as possible.
In the meantime, you are welcome to try any recommendations provided by our fellow community members.
Victor G.
Intel Technical Support Technician
Hello NucNotUp,
We understand that you have already completed a few diagnostic tests on the SSD, and we would like to know if you have tested this NUC with any other SSD? If you did please let us know what other models you have tested and don’t forget to include their brand.
I look forward to hearing from you.
Victor G.
Hello NucNotUp,
Please let me know if you need further assistance.
Victor G.
Hello NucNotUp,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
