I have a Intel NUC NUC8iBEH (Bean Canyon, Intel Core i3-8109U CPU) with Intel Iris Pro 655 graphics. BIOS 0056.
I use 2x DDR4 2400 RAM, a SSD PCIe NVMe as main components.
When installing Windows 10 Pro 64-Bit (1809), Windows Update installes the following graphics driver:
At Intel there are newer graphics driver available. 25.xxx
When I try to install the latest Intel driver I got an error dialog with message similar to "Your system does not meet minimal requirements".
Then I tried the Intel Driver & Support Assistant, which detects that an update for the Intel Iris Plus 655 is available:
But when installing it via the assistant I get an error dialog:
So, what is the problem with installing the latest Intel Iris Plus 655 driver from Intel (website or assistant)? The only driver which installes is the one from Windows Update (24.xxx).
Hope you can help, please fix that driver installation issue, either on Intel side or talk to Microsoft.
Thanks in advance!
Cheers
That is correct; since the DCH driver will only install from .EXE, you need to completely uninstall the existing driver from the Apps and Features scene before you can install the DCH driver. My suggestion is to use this process:
Hope this helps,
first of all you need conform your hardware device id is supported or not , check compatible device id in this post
download the graphics software manually and save in c drive, and then exact using WinRAR or 7-zip .
same error I got last four months back , reasons are when we applying new driver on existing driver .
so you must completely uninstall the graphics softwares uwing revo uninstaller software this software deletes all the files including registry keys also , once completed uninstall means , disconnect the internet .then restart the windows.
now open the folder , run setup with admin rights. after completes restart the windows
Same thing happened to me on a NUC8i7BEH, Windows 1809 insists on installing the .6287 version driver and when it is installed the 6444 from Intel won't install. I had to totally remove it and the Intel Display Audio driver, reboot, and then install using igxpin.exe in the driver package. Then I made the stupid mistake of checking it in device manager and hitting 'update driver' and it reverted me back to 6287! Luckily from there I could choose rollback driver and it brought me back to 6444. Intel and MS need to get on the same page here with these graphics drivers.
Hope this helps,
sorry for the delay, I had problems with my account at Intel.
Solved it like you guys described, first I downloaded the latest Intel graphics driver given at the NUC driver page, then I disconnected from the Web, I used DDU to uninstall the installed Intel graphics driver, afterwards installed the latest one via downloaded setup, after finish reconnected to the Web.
Thanks!
Cheers
