Not sure what happened. all of a sudden the box is dead. disconneed power. reconnected no sign of life
With power adapter plugged into A/C, if you connect it to NUC unit, you should see a LED turn on inside the chassis (take bottom off to see this). Do you see the LED come on? If not, the problem is in the power supply. Does it come on?
Hello NHERS1,
Were you able to review the information provided on this thread?
If you have any further questions, we will be glad to help you.
Wanner G.
Under Contract to Intel Corporation
