Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13514 Discussions
Intel NUC Skull Canyon. Kit NUC6i7KYK
Articlay
I had the nuc for years and never had a video display problem. been using the same cables and the same monitor it always worked great .until I screwed up the hard drive I pretty much had to reformate the SSD and the bios in the Intel nuc .I was missing the uefi set up in the bios it would only do legacy devices I fixed all of that but this issue is something that came out from this it I think. What else can be a good idea to maybe try.. I got the skull canyon NUC6i7KYK. I got the latest bios and updates for it. And it's raining windows 10 64 bit Could it be a bios setting not be configured not right?. Where can you find the actual documentation for th is nucs setting . Does anyone have the pdf of this .? Maybe someone could send it to me please . Thanks
LeonWaksman
Here you have: Visual BIOS Glossary
I understand that you have problems with video signal. Did you installed all relevant drivers?  The first driver to be installed is the Chipset Device Software.
Leon
Articlay
Yes thank you for replying Leon .I also have the Intel driver assistance so all the newest drivers and everything are automatically installed but I'm pretty computer savvy and I never had problems with this until I actually had to reformat my hard drive .for some reason it would not allow me to install Windows 10  64 bit which was originally on there to begin with I don't know what happened it might have and Windows update will they tend to conflict their own updates of operating hardware with Intel operating software drivers and it could cause a lot of problems.i believe  one reason or another might have   corrupted the  operating system somehow . the hard drive began giving me messages saying that it was write protected and in order to actually have it be able to use the the hard drive from legacy to UEFI I had to pretty much change the hard drive format to partition the drive how windows requires you to.  had to wipe everything out and it was a real pain in the butt but I got it to work I loaded the operating system and for the most part it's been able to be used but now it just keeps on flickrring on screen and the  source input with pop up in  the corner of my TV screen as if I was select the source bottom on the TV remote. . . Wondering if it could be a hardware  issue ? Maybe the  video input card portion could be failing or somewhere on the board might start to go . This is the only nuc I ever had  and I've had great luck with it I've had it for years and until most recently of the last update with Windows 10 is what started the whole problem . this  caused my computer major issues and now it's pretty much almost completely unusable cuz I have no patience to have it flicker and try to work on it while it keeps on blinking .you can't even see anything that you're trying to accomplish . Although if you try to put it in the visual bios there is no flickering at all of the TV screen which leads me to believe it's not a hardware portion of the big that's is faulty. Maybe  it's is the setting ? when the process of the operating system is being loaded there's just something that is causing an issue after the BIOS.. thanks for any further advice on this issue.
LeonWaksman
"I also have the Intel driver assistance so all the newest drivers and everything are automatically..." Before using Intel DSA, the Chipset Device Software, must be installed manually. Only then, the IDSA may install the correct drivers.  In addition, your system drive should have GPT partition (rather than MBR) in order to boot from UEFI boot.
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
Articlay
Hey Leon sorry for not getting back to you I was pretty much over this problem.i have to say it was wearing me out. But I finally decided to put the computer into safe mode after reading some stuff on the internet and loading into safe boot. The flickering has stopped but now I don't know if I put this back to normal boot it will stay I assume it won't because whatever is causing the conflict is not in effect when it's safe boo is on I don't know if it's a service I don't know if it's a conflict of windows running certain things in the back round. I tried to download that Intel program. I could not do it while the computer was in normal boo so now I'm going to have to restart in safe mode with networking download that particular program and then-start it into safe boot by itself and see if that will bring up any clues to what is causing this conflict but I've took a picture of my computer and what is sharing or what is conflicting and I hope this helps in the meantime I will get back to you
LeonWaksman
Hi @Articlay
You may perform a Clean Boot (instead using the SAFE Mode) and see if there is some program/service causing the screen blinking.
Leon
