Does any NUC do 24/192 out of the toslink (mini optical) port?
wolf359, Thank you for posting in the Intel® Communities Support.
In reference to your question, just to confirm, is there any particular Intel® NUC model that you are interested in? This is in order for us to try to gather the information you are looking for about Toslink on that specific model.
Is there any particular reason why you need that information?
Are you a developer?
Are you working on a project?
When you mentioned "24/192 out" you are referring to the rates, correct?
Albert R.
A Contingent Worker at Intel
I guess the nuc I am most interested in is the NUC9i9QNX. I am a home user who wants to hook the nuc up to a DAC for stereo music. Yes, 24/192 refers to bit and sample rates.
wolf359, Thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Hello wolf359, I just received an update on this matter.
Please verify the Intel® Technical Product Specification for the Intel® NUC 9 Extreme Kit - NUC9i9QNX, on page 21, you will find all the details about the Toslink feature:
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/nuc-kits/NUC9QN_TechProdSpec.pdf
Albert R.
Thanks for looking that up. But that doesn't answer the question.
@wolf359 You responded to a spammer. I have flagged his post.
wolf359, You are welcome, thank you very much for your response.
I will double-check to see if there are further details about the TOSLINK feature on the Intel® NUC 9 Extreme Kit - NUC9i9QNX and as soon as I get more updates, I will post all the information on this thread.
Albert R.
After further review of the case, just to let you know, we can confirm that actually, the information provided previously was related to the supported Toslink rates, it is not related to cables.
Basically, the Intel® NUC supports the 44.1 KHz, 48 KHz, 96 KHz and 192 KHz sample rates, but it does not support the 24 KHz rate.
Albert R.
wolf359, You are very welcome, thank you very much for your response.
Any other inquiries, do not hesitate to contact us again.
Albert R.
