Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13508 Discussions
Intel® NUC kit NUC8i5BEH Cellular Module M.2
Lakshmi
Is there any reference cellular module which being tested with Intel® NUC kit NUC8i5BEH via PCIe M.2?
As the NUC kit doesn't come with SIM Slot, do we need additional carrier board?
AndrewG_Intel
Hello Lakshmi
Thank you for your response.
After checking this further, and as per the Technical Product Specifications section 2.2.4.2 Add-in Card Connectors, we would like to inform you that the M.2 port on the Intel® NUC is reserved only for an M.2 storage module; and the other M.2 port is reserved for the M.2 2230 pre-installed Wireless module.
Having said that, for the M.2 slot available on the Intel® NUC, other devices different than storage modules are neither supported nor validated according to the Technical Product Specifications.
Andrew G.
AndrewG_Intel
Hello @Lakshmi
We understand that you are looking to know if it is possible to install and use a SIM card or an M.2 adapter to be able to use a SIM card for cellular connectivity (e.g. 3G/4G/5G, etc). Is this correct?
Could you please provide the following details so we can check this further?
1- To install a SIM card adapter, do you mean to use the M.2 port reserved for the Wireless Module on the Intel® NUC for that purpose?
2- Please provide more details about your project and/or what you are trying to achieve.
3- How many Intel® NUCs would be deployed (or how many units would be impacted) for this request/project:
4- What would be the business impact?
Andrew G.
Lakshmi
Thank you.
1. Yes.
2. enabling the NUC to connect to the internet using the cellular network
AndrewG_Intel
Hello Lakshmi
Andrew G.
Lakshmi
AndrewG_Intel
Hello @Lakshmi
Thank you for your response. We hope that the information provided has been helpful to clarify your concern.
Since the thread has been marked as "Solved" we will proceed to close this inquiry now. If you need any additional information please submit a new question as this thread will no longer be monitored.
It has been a pleasure to assist you.
Andrew G.
