Intel® NUCs
12298 Discussions
Intel NUC nic Adapter driver
ItItron
This is for a NUC8i7BEH, with Windows server 2019 installed.  It has the Intel® Ethernet Connection I219-V.
I've tried the following drivers:
LAN-Win10-25.4
25_6
Intel-NUC-Kit-NUC8i7BEH_Win10-64_Drivers.20201218 (bundle)
Intel-Driver-and-Support-Assistant-Installer*
*I used a USB-C to RJ45 adapter to get network access on the device to run the Support Assistant. - Still didn't work.
  I installed Win10 1909, which found most of the drivers including this ethernet adapter, which gave me the correct info.
I searched the HW ID under Device Manager and got no google hits.
The adapter DOES show in Device Manager and it blinks when the cable is attached. And it worked 100% in Win10 1909. I'm confident it's NOT hardware failure.
#1- Does Intel support Windows 2019 Server on this device
#2 - If Yes, How do I get the driver installed?
Thank-you,
WD
AlHill
To answer your first question, No, Windows Server is not supported:
https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html
ItItron
Since Inte's scrubbers removed the actual issue:
No Intel(R) Adapters are present in this computer
AlHill
ItItron
