Community
cancel
Showing results for
Search instead for
Did you mean:
Praja
Intel NUC no boot, click sound. no display
I am having an INTEL NUC that was unused for some time. I successfully installed Ubuntu. After that, I formatted the hard drive as wanted only windows and tried installing Windows. I was partitioning and it got stuck on that screen for a while. I am not sure if I disconnected the power or it shut down automatically. Now it does not even come up.
step 1: 1. NUC switches on.
step 2: 3 blink of blue light followed by a click sound and then it goes off.
It repeats again and again till I remove the power. No display on the screen
Tried changing the hard drive. That is not an issue. memory or HDD should not be the issue as the same issue is seen even without installing both. No display with a simple Power on.Not even the boot menu is seen
n_scott_pearson
Super User Retired Employee
Three blinks means a problem with memory initialization. Since this system was working originally, I would suggest that, with NUC powered off, you remove and then reinsert the memory. If the problems persist, you may have to replace this memory.
Community Manager
Hello parthibaraj84,
Did you follow the steps suggested by N. Scott Pearson?
Please let us know if you need any further help.
Wanner G.
