I have Intel NUC and I have manually assigned it a static IP address to it. Now when I run the Advanced IP scanner on the entire network, I see 2 different IP address to the same mac address on that NUC. I have also made sure other network adapters are disabled on the NUC. Any specific reason it shows two IP addresses ? Is this something related to IPMI ?
Hello Pratik898,
Thank you for posting. We will move this thread to the Intel NUC communities for faster response. To help the NUC community further assist you please provide https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility logs. This will not collect any personal information.
- Download and run the .exe from the link above
- Check "everything" then click "scan"
- When scan is finished click "next"
- Save the log and attach it to a post
Daniel D
Hello Pratik898,
We just wanted to double check if you need further assistance?
We are waiting for your report in order to investigate your issue.
I hope to hear from you soon.
Diego S.
