Intel® NUCs
Assistance in Intel® NUC products
12963 Discussions
Intel NUC10 - Headphone Output not Working
burstcache
I have a NUC Mini PC Kit with non-functioning headphone jack
Product code: BXNUC10i7FNH3
Regulatory model: NUC10FNH
Date of Manufacture: 22SEP2020
OS: Windows 10 Enterprise 1903
The front headphone jack is not functioning and I'm prompted to insert a jack despite one being inserted. This work briefly while I was originally building the unit, once the BIOS was flashed to 0047 it's stopped functioning.
Please help.
Maria_R_Intel
Hello burstcache,
Thank you for posting on the Intel* Community.
Please try the below steps and let me know the outcome:
Check that front panel audio is enabled in BIOS:
  1. Press F2 during start to enter BIOS Setup.
  2. Go to Advanced > Devices > Onboard Devices.
  3. Enable the Audio setting (check the box).
  4. Press F10 to save and exit BIOS.
Download and install the latest Realtek High Definition Audio driver for your Intel NUC version 6.0.8950.1 https://downloadcenter.intel.com/download/29213?product=188811
Maria R.
burstcache
Hiya @Maria_R_Intel
I have followed your instructions. When entering the BIOS and selecting Advanced there is however no Devices options, just Onboard Devices and in there HD Audio is set to Enabled. See attached screenshot.
The drivers have been loaded, reboot performed and the problem is still there.
What shall I try next?
Kind regards
burstcache
Maria_R_Intel
Hello burstcache,
By any chance did you test different headphones? Just to discard. Also, please provide us with the specific Headphone model.
Please provide us with the Intel® System Support Utility (Intel® SSU)
Maria R.
burstcache
Hello @Maria_R_Intel
Headphones tried are:
AKG Y50
SoundMAGIC ES18
Here is the SSU results.
Maria_R_Intel
Hello
Thank you for the information.
We will proceed to check this internally and post back as soon as possible with updates.
Maria R.
burstcache
Thanks @Maria_R_Intel , look forward to hearing back from you and getting this problem resolved. It's very fustrating having brand new hardware what doesn't work properly.
LeonWaksman
Hi @burstcache
Look is Start Menu for Realtek Audio Console and check if your audio device is enabled.
Leon
mirceavlad
@LeonWaksman
Realtek Console was also not working for me at all and still isn't.
Meanwhile I tried uninstalling the Realtek audio driver from control panel.
Then searched the drive C for the keyword "Realtek" - deleted everything it could find.
And that's all. Jack works fine, I have no Audio driver installed. It's hilarious.
Maria_R_Intel
Hello burstcache,
We also want to recommend you to update your Operating System to the latest version 20H2.
Maria R.
burstcache
Thank you @Maria_R_Intel
I have downloaded 20H2 and will perform a fresh install of the OS. What order do I install the drivers?
Cheers
burstcache
burstcache
20H2 installed and then just the Realtek drivers. No detection of the headphones and the following entries in device manager.
Maria_R_Intel
Hello burstcache,
Thank you for let me know the outcome.
We will keep investigating this issue, please expect a response soon.
Maria R.
Maria_R_Intel
For error code 10, please try the below steps:
After updating to the latest BIOS version using the methods above, we recommend that you restore BIOS factory defaults:
  1. Press F2 during boot to enter BIOS Setup.
  2. Press F9 to set factory defaults.
  3. Press F10 to save and exit BIOS Setup.
If the issue persists, please know that we are currently investigating this behavior, so let us know the outcome to share it with the corresponding team.
Maria R.
burstcache
I've followed your instructions with no joy. Realtek show as installed in Apps and Features however never shows in Device Manager.
Maria_R_Intel
Hello burstcache,
Thank you for the update. I will proceed to share the information with the department in charge. I will post back on this thread as soon as I receive any updates.
Maria R.
burstcache
Hello@Maria_R_Intel
Either I am not installing the software properly in which case please tell me what I need to do.
It's faulty hardware, can I get an RMA?
It's faulty firmware, what are your timescales to fix this?
kind regards
burstcache
Maria_R_Intel
Hello burstcache,
Thank you for patiently waiting. In this case, the recommendation will be to proceed with the warranty of the unit.
Please, contact us directly and provide this thread as a reference. Please use the support from your local region https://www.intel.com/content/www/us/en/support/contact-support.html
We will keep the thread open so you can let us know the outcome, in case the issue persists with the new unit.
Maria R.
burstcache
@Maria_R_Intel
"proceed with the warranty of the unit"
This is a very unusual phrase, not one I have encountered before. What do you want me to do and how?
Cheers
Jules
n_scott_pearson
Super User Retired Employee
After verifying that your warranty is still active (here: Determine if Your Product Is Still Under Warranty), directly contact Intel Customer Support to initiate the RMA process (you cannot do this through the forums). Here are pages where you can lookup contact information, including local/country phone numbers, by geography:
You can use the online forms service or email, but I actually recommend calling them directly. The above links provide local or toll-free numbers in most countries and support most local languages. You could also use the chat service (start here: Intel Customer Support Chat), but understand that this service is offered in English only and is subject to the normal (9:00-5:00 M-F) office hours in the Pacific (UTC-8) time zone.
LeonWaksman
Hi @burstcache
Under this link you may check your Warranty Coverage and issue an request for RMA.
Leon
