I have a new Intel NUC 10i7 that the front panel audio currently doesn't work and has been 'hit or miss' (mostly miss) with working since I got the machine at the end of October.
I would appreciate some help in figuring this out. I had an NUC5i3 for over 5 years and it was rock steady. I was expecting the same from the NUC10 but now I'm having buyers remorse.
Thx
-K2
Hello K2,
To better assist you please provide the following reports and information to continue with your support request.
1-Please run the following tool and attach the report generated.
-Intel® System Support Utility (Intel® SSU)
Download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
• Open the application and click on "Scan" to see the system and device information
• By default, Intel® SSU will take you to the "Summary View".
• Click on the menu where it says "Summary" to change to "Detailed View".
• To save your scan, click on "Next", then "Save".
2-Please provide the following information so we can have a better understanding of your issue.
-Do you mind providing us with a screenshot of your device manager's window with the specific error code you got.
Note: To check it please choose the Intel® Smart Sound (Intel® SST), right-click on it, and choose properties.
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Victor -
Thanks for the reply. Attached is the SSU report and several screenshots of the Intel SST OED status from the device manager.
Another data point worth considering - this PC has never booted in less than 90 seconds. From the very first day I had it. My five year old NUC5i5 would boot in 20 seconds. So there is something obviously not right.
Thank you for your assistance,
-K2
Hello K2,
We appreciate the information provided, and we would like to recommend the following steps so you can try to fix the issue.
-Start by performing a cold reboot (hold the power button until the PC powers off and then power on the NUC). If the problem persists, continue to the next step.
-Update to the latest Realtek* High Definition Audio driver.
Realtek* High Definition Audio Driver for Windows® 10 64-bit for NUC10i7FN, NUC10i5FN, NUC10i3FN
*For any download with a ZIP file: double-click the filename.zip to extract the files to a local folder, then double-click the Setup application inside the folder. If the problem persists, continue to the next step.
-Complete a BIOS recovery. If the problem persists, continue to the next step.
Instructions
https://www.intel.com/content/www/us/en/support/articles/000033291/intel-nuc.html
*There are two methods in the link above please try the power button menu one.
Latest BIOS
https://downloadcenter.intel.com/download/30073/BIOS-Update-FNCML357-
-Restore BIOS factory defaults:
Press F2 during boot to enter BIOS Setup.
Press F9 to set factory defaults.
Press F10 to save and exit BIOS Setup.
Victor G.
Victor -
Update on #3 (above) - after actually reading the instructions and downloading the correct BIOS update file I was able to update the BIOS using the F7 power-on recovery method.
Unfortunately it made no difference. I still have no audio. I even tried reinstalling the Realtek drivers following the BIOS update.
-K2
Hello K2,
Based on the information provided and considering the troubleshooting steps completed, our strongest recommendation will be to try contacting us directly to check what will be the warranty options available for you; feel free to refer to this post once you contact Intel Customer Support.
Here is our "contact us" information:
https://www.intel.com/content/www/us/en/support/contact-support.html#@7
We would recommend phone or chat support venues during your regular working hours.
Victor G.
