I just installed Windows 11 onto Beast Canyon (NUC11BTMi9)
It looks like most of the drivers installed. But looking at the Device Manager I still have some unknown devices (Yellow Exclamation Triangles).
Any idea what other drivers needs to get installed?
The chipset software drive logs a list of the onboard hardware. Without this installed, windows try’s to load the generic drivers but they are not hardware specific, thus the yellow bang.
Hers is a link
https://www.intel.com/content/www/us/en/download/19695/intel-chipset-device-software-for-intel-11th-...
Hers is a link
@Amphi Thanks so much, makes sense.
I installed the Chipset Device Software and was then left with the (2) Universal Serial Bus (USB) Controller.
Then I decided to install this one to take of that: Thunderbolt 3 & 4 DCH Drivers
Thunderbolt™ 3 and 4 DCH Driver for Windows® 10 for Intel® NUC
Now, there are no Yellow Exclamation Triangles.
Appreciate your suggestion.
Just wish they add these "Drivers" to the Windows 11 Supported Operating System "list".
All good now!
Thanks!
GWN21
Nothing like pulling your hair out in frustration.
Okay, so I decided to blow away the Windows 11 Install and start over. Did the Windows 11 install, and then the Windows Update and was right back where I was in the original post.
This is for the NUC11BTMi9.
So, I installed the Chipset Driver as noted above and the Thunderbolt 3 & 4 DCH Drivers, also as noted above.
But, this time around the 'Unknown device" remains, as noted in the below screen shot. ARGH!
Everything else looks good, but I haven't a clue this time what to try and install for this unknown device.
GWN21
Sigh...
Found the issue. So this is weird, I could have sworn that I used the same Chipset link and download as before.
But I also found another "older" Chipset file and I used that one and that installed the correct drivers.
It was the "Intel GPIO Controller - 34C6"
The Chipset Driver I 'thought' I downloaded originally was: Chipset-Win10_Win11-10.1.18793.8276
The Chipset Drive that I also had AND used to install the Unknown device 'manually" was: chipset-win10-10.1.18698.8258
And this one resolved the issue of the Unknown device.
Now I'm all good again.
GWN21
