I need directions for making the settings work okay for me. This was a professional problem from the start. It wouldn't go to sleep and wake up right away. And I never ever had a gigabit Intel adapter. It comes with advanced features, for one. Link can work. I don't mind learning new tricks.
Hello lEdge
Is Bluetooth the only thing that wakes up your NUC automatically or does this happen with other actions?
Please attach the Intel® System Support Utility (Intel® SSU) resullts
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
I want to add I'm pretty used to my TV sound bar waking up from sleep when the phone or a laptop computer connects. Because it's designed like that.
On the current situation with the NUC computer I had no idea what was doing it. After a couple of trials I had to make sure the sleep timer was on to prevent all day power for this NUC.
I figured out how to set up the lan packets. More on that is mentioned elsewhere.
Everything in the NUC is basically new to me. That's the problem, and the one that needs the solution.
I don't have any other devices that can wake up from lan, wan, Bluetooth and USB. I'm more used to power button or USB wake-up options.
And too be honest this only happens with the phone in the device list. The laptop seems to be silent in this configuration. And I seriously don't mind having every resource possible in the house wake up the NUC. Except only when intended.
I understand why all the options exist. I also already made changes to the iSCSI boot. I just don't know how Tlingit and Rondo feel about. As they are currently already taking the match spot as qualifying computers.
I'm lost in the document description for the kit. I can only imagine how to wake from the peripheral. Not to mention the reading I done just for today. I can add two or more things to the list added. Such as the S5 states wake up. And wake from CIR devices along with Bluetooth media remotes.
What's the best configuration to convert to waking up the NUC instead of the power button and a USB keyboard mouse combo(Logitech K400+)?
I just want the SSU report to be correct.
For the sake of the community public appearance of this forum this is what the Android 7.1.1 Bluetooth settings are like right now. It has absolutely no effect. And since removing the NUC device. Because it was really bothering me not knowing what the problem was.
I also tried the same thing with the HP laptop communication. I only have an option to send files and attempt to connect to local network. Local network from Bluetooth connection is like news to the two computers. They are already on the same network.
Long story short no effect either. One more thing. I'm pretty sure the phone's Bluetooth is version 3.4 or something in that tenet kennel.
Thank you for all the information provided lEdge.
To to investigate this and replicate the problem we need the full NUC model and the Intel® SSU results, you can provide a new file if you make changes to the system, we'll be waiting for your response.
David G
Oakay. I had some time after work today. More than usuall.
I will give you the SSU report in the attached file. It's just a text file.
I wanted to add that I did not make any HDD changes and everything is as described. Original and untouched. I did add a second HDD along with the new RAM. Don't get confused in the part list. They should be the same parts. Thanks.
Again, please don't forget to mention to quote me. This is not a technical issue. I never really expected the Bluetooth to wake the system up. I hope you can read the BIOS sleep settings. I don't remember them, and I actually forgot to check that. I can say for sure the S3 state must be on. That was the last intention I made any changes in the bios. I did include the BIOS information in the scan.
Thank you for the information provided lEdge. We are working on this request, the updates will be posted on the thread.
David G
Thank you for the information provided lEdge. Please test a clean installation of the wireless drivers, BT drivers included, test the device and let us know if the issue persists. Download link
Steps:
- Clean Installation of Wireless Drivers
David G
David G.
David G.
