Community
cancel
Showing results for
Search instead for
Did you mean:
Intel NUC6i5SYK do not shutdown properly with Ubuntu 14.04 LTS
Hi.
This is my NUC system:
* Intel NUC6i5SYK
* SSD 128Gb M.2 2242 ADATA PREMIER
* RAM: 4 Gb KINGSTON HYPERX IMPACT − DDR4
* External HD: W.D. Elements 5 Tb
* 3 tuners pctv nanoStick in a usb 3.0 hub.
* O.S.: Ubuntu 14.04 L.T.S. (easyVDR 3.0)
With 0028 BIOS, the NUC was not able to shutdown properly. In the shutdown proccess, the blue light turn off for a second but then it turned on again, and It was not possible to start again unless I unplug the electrical power supply or by pressing several seconds the power button. It only shutdowns fine after a boot by removing previously the electrical power cable.
I have updated BIOS to 0036 versión. Now the problem has changed. When I try to shutdown it, it reboots always... unless I remove power supply cable... then after starting, it shutdown fine again... but once... next time it is impossible to shutdown properly again.
I thought that with las BIOS version (0036) the issue will be solved, but it only has changed, and I am not able to shutdown correctly the NUC6i5SYK.
Someone has had this issue and knows how to solve it?.
Javier B.
Highlighted
Hi jbjb,
Let's try to narrow down the issue. Are you getting the same issue without the nanoStick TV Tuners?
Mike C
Highlighted
Hi Mike.
Yes,I have tried today and same behaviour. With 0036 BIOS I have to shutdown twice in order to achieve a complete shutdown. In the first shutdown the nuc restarts, in the second try it finishes the complete shutdown.
Regards.
Javier B.
Highlighted
Hi jbjb,
It is not a common issue with the NUCs with Microsoft® operating system. Intel noted random issues with some memories; please do this work around and keep us posted with your findings.
Go to BIOS>Advanced>Performance>Memory> and uncheck the option Round Trip Latency Optimization
Mike C
Highlighted
Hi Mike.
I have tried changing the option Round Trip Latency Optimization, but the behaviour keeps on.
I have bought another nuc, and, with Ubuntu 15.10, it shutdowns fine. The problem is that I have to use 14.04 LTS in the first NUC.
It is strange because it fails every two shutdowns, it does wrong the first one and fine the next.
I hope there is something else to try. Regards.
Javier B.
