Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
12003 Discussions
Intel NUC7PJYH: no video signal
VSima3
I've bought two Intel NUC 7PJYH with Pentium Silver processor. BOTH of them have the same issue - there is no video signal over HDMI.
Configuration:* RAM: 2 x 4GB crucial DDR4-2400 CL17 1.2 V
* Sasung SSD 850 (120 GB) / SanDisk SSDA-120G-G26
I tried removing SSD/Memory but have no luck in getting any video signal.
Any suggestions?
LeonWaksman
1. What is the P/N of your memory module?
2. Can you try connect your NUCother monitor and/or TV set?
Leon
VSima3
1. I have 3 serial numbers on memory module:
* CT4G4SFS824A.C8FE
* 1CF172F1
* 375996
2. I have connected my laptop to the same TV via the same HDML cable and it is working perfectly. When I boot up my NUC screen of TV flashes for may be 100 ms (black color) and then shows the same: no signal.
LeonWaksman
1. Your memory is compatible.
2. There is a possibility that your laptop is compatible with your TV while your NUC is not. So, please try connect to other TV or or to computer monitor.
Leon
PeterNUC
vsdigitall,
What TV or display are you trying to connect? I observed lots of problems with Samsung 4K TVs and displays.
Peter
VSima3
I have Samsung 4k TV.
However my device works with Full HD monitor!!! Very strange behavior... but problem solved.
Thanks for suggestions.
PeterNUC
Maybe you have "UHD Color" enabled on your Samsung 4k TV. Disabling it might allow you to get the signal. More detail in
RFrie5
Similar to equal experience here.
Connecting a Intel NUC7PJYH via HDMI to an LG Electronics 38UC99-W Monitor
I got most of the time not even a BIOS Boot Screen. The monitor does go for Standby
Turning off HDMI 2.0 Support of in Monitor Settings gives me 3840x1600 30p Resolution.
I had no issues with other HDMI 2.0 sources (Radeons, Geforces).
So the Intel NUC HDMI 2.0 Support is severely broken on (at least) this NUC.
Embarrassing for Intel, it seems they did not do any compatibility testing with
Monitors and TVs available on the market !?
PeterNUC
_rolo_,
Thanks for the info about HDMI 2.0 compatibility issue with an LG Electronics 38UC99-W Monitor. I observed very similar issues, mostly with Samsung 4K TVs and monitors. Looks like it's pretty hard to find a 4K HDMI 2.0 device, which is fully compatible with this NUC.
Peter
