Community
cancel
Showing results for
Search instead for
Did you mean:
BZ
Intel NUC7i TB3/USB-C Port Still Powered After Shutdown/Hibernate
When the computer is shutdown or hibernated, the USB-C/TB3 port is still powered.
In BIOS I turned off USB Power for Yellow port, and enabled Deep S4/S5, but still not resolved.
I have eGPU (Aorus Gaming Box) connected to TB3, and the fan keeps on even after shutdown. I have to unplug the NUC and the fan would then stop.
Community Manager
Hello popoxee,
I understand that the USB-C is still letting the power go through even when the unit is turned off, I apologize for any inconvenience.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
BZ
Here it is
Community Manager
Hello popoxee,
Thank you for your response,
I was able to do some research and I would like to know if you disabled the charging through the USB ports as shown in the image attached.
This is just to make sure and see if this could resolve your problem.
David V
BZ
Yes I disabled that by selecting "OFF" for that option.
Community Manager
Hello popoxee,
Another step I would like to try right now is to update the BIOS version that you currently have. Upon review of the "DxDiag" you currently have the BIOS version 0060, and right now the latest one is the 0062. You can find the latest BIOS version here:
https://downloadcenter.intel.com/download/27571/NUCs-BIOS-Update-BNKBL357-86A-?product=95067 BIOS 0062
You can refer to the link below for steps on how to perform the BIOS update:
https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html BIOS update instructions
Once this is installed, please try to check if the box remains powered even after shutdown, let us know the outcome.
David V
BZ
I updated the BIOS to 0062 and this problem still remains. I believe it could be a bug.
Community Manager
Hello popoxee,
We are going to look more in depth to see what could be causing this, in order to investigate we need more information, please have a look in the following thread and fill out the information that shows there:
/thread/77761 https://communities.intel.com/thread/77761
David V
Community Manager
Hello popoxee,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
BZ
You mean I should post a same info in this thread or somewhere else?
Community Manager
Hello popoxee,
I need the information to be posted here in this thread so we can review it and proceed to do further research and attempt to fix the problem.
David V
Community Manager
Hello popoxee,
David V
BZ
I no longer own this unit. You can close this.
I got a new Skull Canyon and does not experience this anymore.
