Dear Community,
I have Intel NUC7i3BNH with USB-C Displayport and HDMI Port.
My challenge is to connect to Samsung SA 650 which both have only displayport.
So I linked the first screen with USB-C Displayport to Displayport Cable which is working fine.
The second screen should be connected with HDMI to Displayport cable and this is not working.
I have tried two different of this cable, both are not working. HDMI to HDMI is working for example on a TV. Latest HDMI firmware and graphic driver are installed.
Could some give me a hint if there is a compatible cable/adapter available or if any special specifics needs to be considered?
Nic
Hi Scott,
thanks for the hint! I will try such an active adapter.
Because I have used a cable, I guess it was for the other direction of use.
Nic
Yes, absolutely! You can passively go from DisplayPort to HDMI - and that's what that cable supports - but you need active adapter to go from HDMI to DisplayPort. The USB cable off this adapter, BTW, is to provide power to the active conversion ICs.
Hello @nschr
We hope that the information provided by the community has been helpful. Since the thread has been marked as "Solved" we will proceed to close this inquiry now from our end. Communications with community peers may continue, but if you need any additional information from Intel, please submit a new question as this thread will no longer be monitored.
Andrew G.
