Intel® NUCs
Support for Intel® NUC products
12727 Discussions
Intel NUC7i3DNBE eDP output current concern?
Eke
There is a hardware problem.
The NCP SPEC mentions eDP BL_PWR (0.6A total for pins 39, 38, 37, 36). Is this the maximum pin size of 4 pins is 0.6A?
Then is there a mechanism for protection on the NUC?
We actually measure the current more than 1A when the NUC is still working,
I wonder why SPEC is defined at 0.6A?
Thanks for your great support
Hello synnex
Thank you for contacting us; it will be more than a pleasure to assist you.
In order to assist you better please submit a ticket through the right path of support here:
https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
A representative from our Developing Zone will assist you as soon as possible with your inquiry.
I hope this helps, please let me know if you have any other question or concern.
Diego S.
