Community
cancel
Showing results for
Search instead for
Did you mean:
Intel NUC7i5BNK with 24V input voltage?
We are using the Intel NUC7i5BNK and would like to know if we can run it with a 24V power supply instead of the 19V supply?
Any help on this will be greatly appreciated! Thank you.
Highlighted
Super User Retired Employee
No, this is not supported.
If you absolutely must use a 24V supply, you should get yourself a BUCK converter that will drop this down to 19V. Here is an example: http://www.mini-box.com/DCDC-NUC.
Hope this helps,
Highlighted
  1. No, you can not supply 24V to your NUC. See para.2.2.4.6, page 55 in Technical Product Specification https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC7i5BN_NUC7i7BN_TechPr...
  2. You may use 24V to 19V step down converter. For example https://www.amazon.com/SMAKN%C2%AE-Converter-Power-Supply-Module/dp/B00NS7T3B4/ref=sr_1_3?crid=1ZN6O...
Leon
