Intel® NUCs
Assistance in Intel® NUC products
13314 Discussions
Intel NUC7i5BNK with 24V input voltage?
PKett3
We are using the Intel NUC7i5BNK and would like to know if we can run it with a 24V power supply instead of the 19V supply?
Any help on this will be greatly appreciated! Thank you.
n_scott_pearson
Super User Retired Employee
No, this is not supported.
If you absolutely must use a 24V supply, you should get yourself a BUCK converter that will drop this down to 19V. Here is an example: http://www.mini-box.com/DCDC-NUC.
Hope this helps,
