Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13513 Discussions
Intel NUC8i3BEK - How can I disable iSCSI in the BIOS?
UMath
I have an Intel NUC8i3BEK.
In the BIOS there is the setting under:
/Devices / Add-In Config / iSCSI Configuration
My question:
iSCSI should not be active externally.
iSCSI should not be accessible from outside.
Alberto_R_Intel
UMath, Thank you for posting in the Intel® Communities Support.
In order to provide the most accurate information, we will do further research on this matter to confirm how to disable the iSCSI option in the BIOS, as soon as I get any updates I will post all the details on this thread.
Alberto R.
Under Contract to Intel Corporation
Ronny_G_Intel
Community Manager
Hi UMath, I dont think there is a way to disable the iSCSI option within the BIOS. Is there any particular reason why you need to do that? Thanks, Ronny G
UMath
Hello Ronny G,
Thank you very much for your information.
I would like to install Debian 10 as an OS on the NUC8i3BEK.
When I then connect to the Internet via the OS, I am afraid that I am vulnerable from the outside. Because yes the iSCSI is activated.
UMath
Ronny_G_Intel
Community Manager
Hello UMath, Thanks for replying back. I asked around among the product team and there is no way this option can be disabled in BIOS. I would recommend that if you really need to disable it, perhaps doing it at the Operating System level is the only option. I do not know how to do so in Debian 10 (Linux in general) but I am pretty sure that there should be a command to do so. I would investigate with the Linux community. I hope this helps, Ronny G
