Hi
My NUC's HDMI and mini display port connection is fine with the LG and BenQ monitors but there is no display with the Samsung TV. Microsoft Windows 11 is updated and Intel driver and support assistant is also updated.
Please suggest the fix.
There should be no any problems with connecting your NUC to the TV:
1. Use certified HDMI cable/try an other HDMI cable.
2. Using the TV Remote Control, select the applicable HDMI input. For example if you connect your NUC to HDMI2 input, select the Source HDMI2 in order to see the video from your NUC.
3. In BIOS, Advanced > Video, select the HDMI as the IDG Primery Video Port.
Leon
