Intel® NUCs
12121 Discussions
Intel Nuc 7 Home only boots to black screen?
jslat5
Intel Nuc 7 Home only boots to black screen reading Intel NUC. After 5 minutes blue LED front changes to red and then back to blue as a reboot. Its running in ventilation. Powered off and back on. Unplugged re-plugged. Nothing Help? Tech support phone call was a painful disappointment.
n_scott_pearson
Super User Retired Employee
Please provide the proper model for your NUC. From what you've provided, it could be any of a number of models.
jslat5
n_scott_pearson
Is this a new build? If not, what was happening just prior to it being in this state? Did anything change or get changed? Did the, for example, monitor you have it connected to change? What about the cable you use to connect them? You indicated that you tried various power cycling operations. What else did you try? Have you tried clearing CMOS? Have you tried to get to the Power Button Menu (by holding the power button down for three full seconds when powering on)?
jslat5
Original build from 4/18. Been running fine. I didn't change anything. Same monitor. Cabling all the same and seeing the "Intel-NUC" text on the display the cable connection still good to go. Clearing CMOS - couldn't access. Tried holding power button down 3 seconds but never got to menu. Total mystery.
n_scott_pearson
Ok. I can only suggest that you try a different cable and, if you can, a different monitor/TV. If the problem remains the same, then you will need to contact Intel Customer Support directly and set up an RMA replacement of the unit.
Sorry I didn't have a better answer,
jslat5
Thx for feedback. I did go ahead and do that and still nothing. Intel RMA set up.
