I am running a sceptre 30” ultrawide via hdmi and a lepow 15.6” portable monitor vis usb c and power is connected for work. The sceptre works fine but the lepow flashes off and on every 30 seconds or so. I updated the bios and all the drivers last night and that got it working this good. Prior I could not get the lepow to display anything. Any ideas?
- What are the resolution and refresh rate settings for each of your monitors?
- BTW, the R.H. monitor on the attached images doesn't look like Lepow 15.6 portable https://www.amazon.com/Portable-Monitor-Computer-1920%C3%971080-Protector/dp/B07RGPCQG1
Leon
I have tried adjusting the resolution and refresh rate for both monitors. I also updated every driver and bios last night.
- You tried to adjust the resolution and refresh rate of the displays. What are the results?
- If only Lepow display is active (the Sceptre is OFF), still you see the flickering?
Leon
