Intel® NUCs
Support for Intel® NUC products
12504 Discussions
Intel Nuc HADES CANYON NUC8I7HVK (Win 10 pro)- leds problems during switching on or switching off
William77
When I shut down the Nuc, randomly, the led lights (including skull), stay on.
Sometimes it happens instead, that the Nuc shuts down correctly, but at startup only the red hard disk light turns on, while all the others remain off.
The only way to temporarily reset the problem, is to remove the power cord and put it back again, but it works for a short time: if you use Nuc for a few hours, the problem returns.
I have already replaced the Nuc with a new one, but it has the same problem, despite a clean install of windows 10 pro.
I have read, in this forum that many users have similar problems, but it is not clear how they solved them.
Please help, thank you.
William77
Hi @georgenistor
Please can you send me a screenshot of what you have done in your Bios ? I want to be sure of making the same setting as you.
Thank you. We must find a solution for this problem. Nuc is so an expensive machine and it must have no issuses !
William77
Hi @Alberto_Sykes
My NUC still gives me problems to the LEDs, I have read that many other users also have the same problems, despite the things made to try to solve.
What do we have to do ? We want a permanent solution please, it is very inconvenient to unplug the power cord every time this happens !
Alberto_Sykes
Hi William77, Thank you very much for letting us know those updates.
We are sorry to hear the issue persists and we will continue with our research on this matter.
Please provide a new updated version of the SSU report so we can continue with our investigation on this case:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
Albert R.
William77
Hi @Alberto_Sykes ,
find attached the report.
William
Alberto_Sykes
Hello William77, Thank you very much for providing the SSU report once again.
We will continue with our research on this matter, I will let you know on this thread as soon as I get any updates on this topic.
Albert R.
William77
Hi @Alberto_Sykes
Thank you, I hope to solve soon.
William
Alberto_Sykes
Hello William77, I just wanted to confirm if you were able to install and test the BIOS and if you need further assistance on this matter?
Albert R.
William77
Hello @Alberto_Sykes
yes I was able to install and test the BIOS.
At the moment the leds turns on and off correctly.
Please don't close this thread, I want to test it for another week before making a final judgment,
Thank you
William
William77
Unfortunately today when I was turning off the NUC, the LEDs remained on and I had to remove the power cable as usual, despite having installed the new bios HN8065. The problem has not been solved yet ....
I'm waiting for your instructions, thanks
William
Alberto_Sykes
William77, Thank you very much for letting us know those results.
We are sorry to hear the problem is still present. We will continue with our research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
William77
in addition to the issue of leds that sometimes don't turn off, I want to say to you that yesterday the NUC turned off correctly but this morning when I have pushed the power button, all the leds remained off except the red led of hard disk activity....sometimes this also happens
William
William77
I have a HD TV connected via HDMI and I have disabled the CEC function on my TV and on the NUC and it works, no leds issues.
This solution was mentioned by @Gaz2613 user.
Ronny_G_Intel
Community Manager
BIOS 0066 https://downloadcenter.intel.com/download/30320/BIOS-Update-HNKBLi70- should resolve this issue.
Thanks everyone for your understanding and patience.
If after running the BIOS update to version 0066 your system is still exhibiting the same issue, please reach out directly to Intel Customer Support, here is our contact us information: https://www.intel.com/content/www/us/en/support/contact-support.html#@7
Ronny G
