Intel® NUCs
Support for Intel® NUC products
12737 Discussions
Intel Nuc beast canyon not switching on
MdJ83
I just bought a beast canyon. Installed the memory and hard drive. Switched it on with the usb to install windows where it started the process. When i return later the unit was off and when pressing the button to switch on nothing happens
Jean_Intel
Hello MdJ83,
Since you mentioned that you just bought the unit, I recommend you go to the place of purchase in order to get warranty service. Usually, the resellers have a warranty policy for the first 30 days. The support is often faster than Intel, especially if you want a refund for the product. During the initial 30-days from the purchase date, Intel recommends that you seek warranty support by the place of purchase (POP)
Also, to better assist you, please provide me with the following:
  • Can you confirm the exact model of your Intel® NUC?
  • What is the make and model of the RAM, SSD, or Hard Drive installed?
  • What is the behavior of the power button? Is there any type of LED pattern?
  • Did you confirm that the Windows installation process was completed?
Jean O.
Jean_Intel
Hello npatil,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello MdJ83,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
