Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12545 Discussions
Intel® Serial IO Driver for Intel® NUC - install messages
RPear6
Every time I reboot I'm asked to install 'Intel® Serial IO Driver for Intel® NUC'
I install it and then get the same message again. Any ideas on how to fix?
AlHill
Which nuc?
Yeah, I was in a boot loop with idsa.  After I cleared the loop, I uninsralled IDSA.  Better to deal with drivers yourself rather than wait a month or more for idsa to fixed.
Doc
RPear6
My system is
Model
NUC10i7FNB
Version
K61360-302
RPear6
so uninstall the support assistant?
AlHill
You might try disabling idsa startup in the task manager.
Doc
RJamm
Same problem with my NUC10i5FNH.
The real problem: some of the NUC drivers (or Comet Lake-U drivers generally on other systems; I have an ASUS Zenbook UX434FAC with i7-10520U with similar driver confusion) and even BIOS updates are also updated automatically by  WIndows Update (see drivers section in the WU update history).
In the case of Serial IO drivers and a few others, Windows Update and IDSA are competing with each other about the driver superiority. Both install the same drivers but don't accept the other's existing installation.
And there is still the third case, like Thunderbolt drivers, where neither IDSA nor WU care about the driver  and there is only the manual way.
Intel and Microsoft! Clean up this mess and issue clear driver update rules!
