Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12547 Discussions
Internal USB3 motherboard header NUC7i7DNBE doesn't work with passive cable properly, but works with active adapter, is that intended?
Russell
A while ago I purchased the recommended Gorite USB3 motherboard header to female USB3 port cable here: https://www.gorite.com/dawson-canyon-usb-3-0-female-to-10-pin-header-cable
I wasn’t able to get any USB3 devices to work with this cable, only USB2, but USB3 devices worked fine with the onboard NUC USB3 ports.
I posted in the forum about that issue, but was unable to resolve it.
I gave up on that and purchased a different adapter from the same recommended Gorite manufacturer: https://www.gorite.com/dawson-canyon-audio-bracket-with-usb-3-0-port
This adapter does work! But it has onboard electronics - its not a passive adapter. The onboard NUC USB3 header connects to the adpater which has a small IC chip which then goes to a female USB3 port. While I'm happy it works, I don't really understand why in IC is needed (I would rather use a passive cable than a chunky active adapter). Can you confirm that the USB3 motherboard header pinout is designed to feed straight into a regular cable and not via some kind of IC?
Russell
LeonWaksman
Hi Russell,
There is electronics on the bracket this bracket, since this bracket include the audio port. I don't know why the cable you tried first didn't work. Could be some failure or wrong installation. Here you have another and better option without electronics: https://www.gorite.com/intel-nuc-dawson-canyon-expansion-usb-bracket
https://techsterweb.com/2018/03/13/dawson-usb/
Leon
Russell
I don't believe the electronics I'm referring to are for the audio, as the audio IC is fed from a separate USB2 connection which connects to the USB2 motherboard header on the NUC.
I might try purchasing that bracket as well as a test, although it looks suspiciously identical to my two that don't work (Just without being attached to a bracket).
What I don't get is why the audio bracket has an USB3 grounding cable and the other USB3 cables/brackets don't.
n_scott_pearson
Super User Retired Employee
The NUC offers only a single USB 3.0 port via the internal header. In order to support both the external USB 3.0 port as well as the Audio IC, a USB 3.0 Hub is included in the bracket's electronics.
I do not know why you had issues with the original cable. Perhaps it was bad. I would have GORITE replace it and find out.
Hope this helps,
P.S. I like the idea of this audio bracket, but I would really like to see them offer one that provided me with 5.1 channel audio support and included a TOSLink output.
Russell
Sorry, I forgot to mention the Audio IC has its own USB2 connector which connects to the USB2 header on the NUC. Although theree's always a chance that its using USB3's power supply to supplement the Audio IC or something crazy.
I actually bought two of the cables so I'm not sure if a replacement would behave any different, but I have written to GORITE detailing the issue - we'll see what they say.
n_scott_pearson
I have the USB expansion brackets that Leon pointed to in my DN NUCs, BTW. They have worked ok for me, though I have only used the USB3 port for flash drives so far.
