Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Internal vs External Power on DE3815TYBE
In section 2.2.4.4 of the DE3815TYBE technical specification it indicates that the NUC can be powered from the internal connector using +12VDC -10% though +24VDC +10%. However, external power has a maximum voltage of 19VDC +10%. Why is this? Is there some circuitry between the internal and external connector that prevent apply +24VDC + 10% to the external connector?
I would like to have confidence that I can power the board externally with +24VDC without damaging it.
Below is a link to the document I'm looking at:
http://downloadmirror.intel.com/23745/eng/DE3815TYBE_TechProdSpec06.pdf http://downloadmirror.intel.com/23745/eng/DE3815TYBE_TechProdSpec06.pdf
Jacob
Tags (1)
Highlighted
Jacob all the information regarding your inquire could be found at the following thread
Highlighted
Thanks Sylvia,
This thread is helpful but doesn't answer two of my questions. I've added the questions to the end of the thread you linked to.
Jacob
Highlighted
Any word on this?
Jacob
Highlighted
Jacob, we replied to you at the other thread
