Community
cancel
Showing results for
Search instead for
Did you mean:
chrism311
Iris Xe adaptive sync
Does the NUC i5-1135GY Iris Xe adaptive Sync support AMD's Freesync.   Can I buy any monitor with Freesync capability and will it work with the NUC Iris Xe integrated graphics?  Oh, should I use a HDMI or Displayport cable for connection?
Labels (2)
Victor_G_Intel
Hello chrism311,
In order to better assist you please provide the following log so we can move forward with your support request.
-DXDIAG
•          Go to Start > Run or Windows Key + R.
•          On the Run prompt, type "dxdiag" then click OK.
•          On the DirectX Diagnostic Tool window, click on Save All Information.
•          Browse to a folder, type in a filename then click Save.
Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
I look forward to hearing from you.
Victor G.
chrism311
please find attachment
Victor_G_Intel
Hello chrism311,
We will complete further research about your request, and we will update this thread as soon as possible.
Victor G.
Victor_G_Intel
Hello chrism311,
Based on our research we need to inform you that the only company who can actually validate the information that you are requesting in regard to that technology will be AMD itself; therefore, our strongest recommendation will be to check the compatibility with them directly.
Down below you will find a couple of links to get in touch with them:
AMD support
https://www.amd.com/en/support/contact
AMD support forums
https://community.amd.com/t5/support-forums/ct-p/supprtforums
Victor G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Victor_G_Intel
Hello chrism311,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello chrism311,
We have not heard back from you.
Victor G.
