Intel® NUCs
Support for Intel® NUC products
12746 Discussions
Is CAD file for the motherboard of NUC7i3BNK available?
IPC00
Hi, from the manual, although there are some drawings, the exact location of the four screw holes at each corner are not clear. Is there a CAD data file for the motherboard?
IPC00
Thanks. In my case, is NUC7i3BNB (NUC7i3BNB-STEP.ZIP) the one to use?
IPC00
Thanks. I opened the CAD file in SolidWorks but it got lots of built-in errors. Can somebody fix the errors or if there is another working file, please let me know.
AndrewG_Intel
Hello IPC00
We are checking this thread and we would like to know if you need further assistance. If yes, could you please provide the following information?
1- How many Intel® NUCs do you have that may be affected by this issue?
2- Are you designing or integrating components on the Intel NUC or are you integrating the Intel® NUC motherboard into another system and/or custom chassis? Please provide details.
3- Please elaborate more on the issues you have with the flies from the link shared by the community when you try to open them with SolidWorks. You may also provide screenshots or a short video to illustrate better the issues.
Andrew G.
IPC00
Hi Andrew, thanks for your reply.
I am making a prototype as a first step and see how it goes. I am integrating the Intel NUC motherboard into an embedded system. I am designing custom chassis for it so I need the exact screw holes locations and acceptable outer diameter of the standoffs so that they will not collide with the electronic components on the motherboard. Attached is the screenshot for your reference. I have tried several times but always end up with a bunch of rebuild errors.
IPC00
Clicking the "Close" button to close the window and the model did not show up.
AndrewG_Intel
Hello IPC00
Thank you for your response and all the details provided. Please allow us to look into this and we will be posting back in this thread as soon as more information is available.
Andrew G.
AndrewG_Intel
Hello IPC00
Thank you for your patience in this matter.
The issue with the CAD file has been fixed, we tried it and it works for us. Could you please test it and let us know if it works for you?
Should you have additional inquiries, please let us know.
Andrew G.
AndrewG_Intel
Hello IPC00
We are checking this thread and we would like to know if you need further assistance. Should you have additional inquiries, please let us know.
Andrew G.
AndrewG_Intel
Hello IPC00
We have not heard back from you so we will proceed to close this inquiry. If you need further assistance please post a new question.
Andrew G.
IPC00
Hi, where can I download the fixed CAD file?
