Intel® NUCs
11792 Discussions
Is NUC and windows 10 compatible with virtualbox
GRudo
n_scott_pearson
Super User Retired Employee
Yes, you should be able to run VirtualBox on top of Windows 10 on most NUCs.
You know, if you use Windows 10 Pro as your host, Microsoft provides a free add-on hypervisor, called Hyper-V, that you an use. Hyper-V was the replacement for Windows Virtual PC.
Hope this helps,
GRudo
Thanks. I thought hyper-v was just something I had to disable to use virtualbox. I will try it. I wanted to use vagrant with it and a quick search showed vagrant supports it.
J.
