Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Is it possible to retrieve data from IoT Dashboard into a simple html website?
Jump to solution
Hi!
I'm new in the IoT world. Following some tutorials I've successfully configured my Edison and the IoT Analytics account. I can see the temperature data in the Dashboard and everything seems to work fine. But I have a problem and after searching for two days I don't know how to proceed: Is it possible to retrieve data from Intel IoT Dashboard into a simple html website? I don't want to create an Actuator for the Edison or an alert, only a way to see the data in a custom website, but I'm lost. I've found some information about the REST API but I don't know anything about web services. Is there a simpler solution? Any ideas?
Thanks in advance.
Tags (1)
Accepted Solutions
Highlighted
Valued Contributor I
If you know Python, I would do it with Python and Flask web framework. If you don't want to use the web service, you can extract the html data using XPath. You right click inspect the element within Chrome and get the path of the html tag you want to access its data. After that you use Jinja2 included with Flask to create your webpage with the data in it.
Highlighted
Highlighted
I don't know Python but I will try, thanks for the suggestion. Any other ideas?
Highlighted
Hi Fernando,
You can also work with the data received in the board, without using the website with the Dashboard. For this, you can use http://httpd.apache.org/ apache2 or https://nodejs.org/ NodeJS. You can install apache2 following http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html the instructions in here. NodeJS is already available in the image.
There are a lot of examples in the Internet about this that you may find helpful:
http://docs.mongodb.org/getting-started/node/update/ Update Data with Node.js — Getting Started With MongoDB 3.0.4
http://www.no-margin-for-errors.com/blog/2010/07/26/deliver-real-time-information-to-your-users-usin... Deliver real-time information to your users using node.js
Charlie
Highlighted
Finally I've tried to go with Python and Flask and it seems to work with the REST API of the IoT Kit. I've been able to retrieve the information but for now only in the console, not in a website. It's a steep forward so I will continue with this approach. Thank you very much for your help.
Highlighted
That's great fernando!
By the way, you can look at the "requests" Python module (get it with pip). It will help you a lot with http requests and getting json data.
If you need help with Flask, I can give you some pointers.
Also, you can fork my repo on github : https://github.com/speccy88/Flask-Examples https://github.com/speccy88/Flask-Examples
They are Flask skeleton with jQuery mobile, Angular, winjs...
Good luck :)
