You can't update bios from Linux. You can however update bios using F7 method or performing Bios recovery from Power Button Menu or with Yellow Security Jumper removed: https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html
In the table you will see also links to two other possibilities that can work: UEFI bios update and iFlash Bios update. I prefer to use the F7 method or Bios recovery method.
Leon
Thanks for the feedback, Leon. Unfortunately, the units requiring update are at remote locations. Since you confirm that there is no remote solution, we will need to utilize a local method-, such as the two you have pointed. -BR, John
You can always choose to instead purchase enterprise-level NUCs, which support AMT and remote console access. There are a number of board- and kit- level products supporting these capabilities: NUC5i5MYBE/NUC5i5MYHE/NUC5i5MYKE, NUC7i5DNBE/NUC7i5DNHE/NUC7i5DNKE or NUC7i7DNBE/NUC7i7DNHE/NUC7i7DNKE. These are more expensive, of course (manageability, especially remote manageability, is certainly not free).
Thanks for highlighting the the NUC models supporting remote management. Points well taken. Now the challenge is to make a compelling cost / benefit argument to upper management for future deployments:-) -BR, John
Management always balks at the cost of manageability. Every once in a while you encounter a manager who has the vision to see the value proposition (alas not often enough). Use examples of worst-case scenarios to highlight the costs for field visits.
