Community
cancel
Showing results for
Search instead for
Did you mean:
RWalt4
Is it possible to use gvt-g with Intel NUC 7i5DNH
I followed the gvt-g setup guide on github.
The guide worked well on a ASUS P9X79 Pro with Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz under Debian Strech.
But with Intel NUC 7i5DNH and Ubuntu 16.04.4
the command
ll /sys/bus/pci/devices/0000:00:02.0/mdev_supported_types/
failed with directory not found.
Tags (1)
Community Manager
Thank you very much for contacting the Intel® Communities Team, fernwalter.
Allow me to perform a deeper research regarding this inquiry you have, once I have an update I will let you know.
Antony S.
Ronny_G_Intel
Hi fernwalter.
I would assume that you are referring to Intel® Graphics Virtualization Technology (Intel® GVT) for Linux*
If I am correct and that is the case, I have to tell you that we dont support 01.org through this community. I would recommend that you look at possible support options within https://01.org/community Community | 01.org
Ronny G
