Intel® NUCs
Assistance in Intel® NUC products
13303 Discussions
Is the problem of no HDMI signal solved?
SFere
I still cannot use hybernate mode on my NUC7i5BNK (recent Windows 10 prof, recent drivers). The reason: After waking up the PC with mouse or keyboard the blue LED of NUC turns on, but the display gets no signal. The only way to recover from this is to hard shutdown PC. That's annoying, not least because the NUC keeps coming back on by itself, you have to press the power button three or four times and hold it for at least 10 seconds until the NUC finally gives up trying to start again.
Only then can you boot the NUC from Scratch and the display will receive a signal. My Display is connected via HDMI (tried DP, but no change; tried high end cable; display is LG 4k; tried to switch off and on the display and tried to change sleep mode for display in Windows to "no"; did update HDMI driver to recent version).
To clarify: This is not an issue of NUC not waking up - it does according to the LED. And it is not an issue of display going into sleep mode and not coming back. Display is set to never go into sleep mode.
n_scott_pearson
Super User Retired Employee
Download this BIOS release as a .BIO file and then reinstall it using the BIOS Recovery process. This is documented here: Intel NUC BIOS Recovery Update Instructions.
Hope this helps,
n_scott_pearson
It sounds like you are using a very old BIOS. Download and install the latest BIOS and see if this alleviates your issues.
H​ope this helps,
SFere
Hi Scott,
thanks for input. I forgot to mention the BIOS. It's BNKBL357.86A.0079.EB, which should be the most recent.
Stefano
n_scott_pearson
Hope this helps,
SFere
Hi Scott,
after a while of testing I can confirm that it did the trick. I installed the same BIOS update as before, only this time in the described way. Can't believe that one not only has to patch, but even "patch" the way to install the patches.
You spend a lot of time to help - really great job.
Stefano
MMane1
same issue was with me but it got resolved, problem is with my minHDMI to HDMI converter also SSD was not detecting :)
David_V_Intel
Hello SFere,
Were you able to check the posts and recommendations above?
Let me know if you need more assistance.
David V
Under Contract to Intel Corporation
David_V_Intel
Hello SFere,
Please contact us if you have any additional questions.
David V
A Contingent Worker at Intel
