I'm talking about the directs header pins on the motherboard, those which on the NUC5iX series are displayed in the technical manual (see attachment 1), but in the NUC6iX series are not only absent in the manual, but they haven't been even soldered on the motherboard. The same with the NUC5PGYH model.
They are still present as contacts on the motherboard, but need to be soldered directly.
Attachment 1 - NUC5i5 header pins. Attachment 2 - NUC5PGYH header connectors without pins.
I had to solder 2 wires for the remote power trigger and 2 wires for an activity LED.
On that model these connections are even double, why? They both work.
Long story short: if I solder wires on the header connectors, is the NUC warranty still valid?
No, the warranty is void since you have physically modified/damaged the board. Look under "What is physical damage?" here:
http://www.intel.com/content/www/us/en/support/services/000006268.html Warranty Services FAQ
Doc
Doc
Thank you very much for such a fast reply.
Do you suggest to remove the soldered wires before sending it through the RMA?
If you've added wires, you've voided your warranty and you cannot send it back. Whether the wires are there or not really doesn't matter; Intel is not going to take it back.
But why? I did nothing that is listed in the FAQ.
"Screwdriver damage
Trace damage
Connectors and sockets
Recommended actions to reduce or prevent damage
Develop proper handling guidelines"
I read all these cases and what I did is not listed.
Why Intel provides a remote power on/off (as well other remote solutions) if the only way to achieve it is to void the warranty?
I am a "maker", and Intel's NUC boards should be the perfect choice for people like me, but if the warranty is void, what's the point at all?
I am going to say two things:
I am not an Intel representative (well, not anymore, I am retired) and thus not the one you should be arguing with. I believe their response will be the same, however.
What about in cases like this: http://www.gorite.com/intel-nuc-hdmicec-adapterbroadwell-series-5th-gen-p8-nuccecv1-5 Intel NUC HDMI-CEC Adapter - Broadwell Series (5th Gen)
That's an Intel-approved partner selling an item with the following in the description: "NOTE : This unit will require you to solder 2 wires to your NUC PCB ( Red and Grey wires)".
Same response. By my interpretation of the warranty, you would be voiding your warranty if you perform this operation.
As I am an old guy, I remember my successes at repairing and modifying single-layer boards. I also remember my failures at trying the same on multi-layer boards.
Doc
I was being a little facetious. I agree with you, it likely voids the warranty.
Hello:
Thank you very much to all the peers working on this thread, your comments are very useful.
To cpx1:
I just wanted to confirm the information posted previously as correct, if you soldered the header pins that will avoid the warranty, because as it was mentioned before, it is consider a physical damage.
I sent you a private message.
Alberto
For more complete information about compiler optimizations, see our Optimization Notice.
