Community
cancel
Showing results for
Search instead for
Did you mean:
SHa4
Issues with wake from sleep INTEL NUC NUC8I7HVK
Jump to solution
Hi guys,
I've had the Intel Nuc NUC817HVK for a couple of days now and need some advise.
I've noticed when the system goes to sleep, upon wake up non of the ports seem to function correctly.
No USB devices work including keyboard/mouse to log back into windows and HDMI no signal to monitor.
Only way I've been able to get it back working is forcing power off, removing power cable and then it seems okay on startup.
Running all of the latest drivers and latest bios.
I hope someone can shed some light as to why this is happening.
DLang6
I had the same issue after the 44 BIOS update. I downgraded to the 40 BIOS and the problem disappeared. I used the F7 method with a USB stick.
DLang6
hubick
New Contributor II
Yeah, I'm not experiencing this with the v40 BIOS either.
I am a little confused about the sleeping in general though... when I tell Windows to sleep, it seems the power light on the NUC starts blinking slowly, which I assume means it's sleeping, but when I return later, it appears totally off/black.
When I hibernate, it goes totally black right away. Neither sleep nor hibernate result in the 4K TV I use as a monitor immediately displaying "no signal" (so it will eventually shut itself off) though - so I just manually power off the screen.
n_scott_pearson
Super User Retired Employee
Remember that there is a timeout for hibernation as well. If it sits in the Sleep state for long enough, it will then transition to the Hibernate state.
If it is making it into the Hibernate state, pressing the power button should bring it back out fairly rapidly.
SHa4
Thanks guys, I will give this a shot!
SHa4
Thanks for input. I have reverted back to 040 bios after much difficulty in being able to achieve this. Will report back if this resolves my issues.
I don't think the system went into hibernate - and even so the power led and activity lights did come back on after pressing the power button from a flashing state, just none of the ports were behaving properly.
SMcKe
Sleep isn't even an option on my NUC8i7HNK. It isn't even present on the Power settings window. Did Intel remove the sleep capability because of these issues I wonder?
Community Manager
Hello, smckenna. Thank you for joining this thread.
If the troubleshooting steps above did not work for you, please create a new thread explaining your problem. Make sure you include your system configuration and a clear explanation about the issue so we can give you a solution as soon as possible.
I recommend you as well to update Windows 10*.
Antony S.
Under Contract to Intel Corporation
