Community
cancel
Showing results for
Search instead for
Did you mean:
JWhit22
Keyboard boot
Jump to solution
is it possible to power on using the keyboard?
NUC7i5, bios 0060
n_scott_pearson
Super User Retired Employee
Of course. To enable it, you need to make some changes in your BIOS configuration. During BIOS POST, use the F2 key to enter BIOS Setup (the Visual BIOS program) and then click on Advanced. Then,
  • In Devices / USB, ensure USB Legacy is enabled and that USB Port that keyboard is plugged into is enabled.
  • In Power, ensure that Deep S4/S5 is disabled and that USB S4/S5 Power and Wake on USB from S5 are enabled.
Hope this helps,
n_scott_pearson
Hope this helps,
JWhit22
Thank you very much, worked like a charm :-)
