Intel® NUCs
12147 Discussions
Keyboard use in Intel 7th Gen i5 NUC - NUC7i5BNH
mike5
Keyboard: Lenovo 73p5220 External Wired USB Preferred Pro USA Keyboard ( 41A5289, 89P8530)
https://www.amazon.com/gp/product/B000AOYWVE/ref=ask_ql_qh_dp_hza
I plan to use this keyboard Intel 7th Gen i5 NUC - NUC7i5BNH
. the nuc has usb ports. would this keyboard work with the nuc or does this keyboard directly fit into any non-usb port?
AlHill
If it is a wired USB keyboard, it should work in usb port.
Doc
mike5
The vendor says that it is "external wired USB." They also say that this Preferred Pro USB Keyboard is very similar to those that come standard with ThinkCentre desktop systems. It is also compatible with USB enabled ThinkPad notebook systems and docks.
Given this description, would it work with the NUC?
Sorry for the basic question, I'm from non IT field.
AlHill
"ANY" usb wired keyboard "SHOULD" work. The only absolute way to answer this is for you to try it. After all, it is just a wired usb keyboard.
Doc
