Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13499 Discussions
Kingston A2000 M.2 SSD problem Intel Nuc5i3RYK
Mpothoven82
I tried to upgrade the 64Gb Sata M2 SSD in my NUC5i3RYH and after several tries I got into the Windows 10 setup (I had to enable Legacy boot). The problem I now have is Windows setup doesn't create the right partitions.
The error I get is "Windows cannot be installed to this disk. This computers hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu"
If I try to boot in Legacy it says there is no boot drive detected.
Does someone have a solution, or is the SSD not supported?
AlHill
You need to be in UEFI mode.  If your bios is not updated, it should be.
And, you should create your Windows 10 install media from here, following the Microsoft instructions:
https://www.microsoft.com/en-us/software-download/windows10
When you boot your install stick, select the UEFI option.
Do a custom install, deleting ALL PARTITIONS on the A2000, but do NOT format.  Select the unallocated partition, and let windows do the rest.
Mpothoven82
I've created the USB with the Microsoft tool and the USB is in UEFI mode if I check it at the boot devices. Bios is the latest version.
I can see the A2000 as NVME SSD in the bios but it doesn't show up in the boot devices when pressing F10. Deleting the partition also doesn't work, I get the same error message when trying to install Windows 10. Booting without legacy mode turned on gives me the "no boot devices detected" error.
AlHill
the A2000 is not going to show up in boot devices until you have an OS installed on it
Mpothoven82
Tried again, got into Windows 10 setup but when selecting the partition I get this (sorry it’s in Dutch)
AlHill
Sorry, I cannot read Dutch.  Translate it for me.
Mpothoven82
It cannot create a new partition or find a existing one. When I click on it I see this:
AlHill
In your bios, You have selected UEFI, and your SATA mode is AHCI?
In the Custom Install, after you deleted all partitions on the ssd, it is saying "unallocated space"?
When you booted the install stick, you booted it in UEFI mode?
AlHill
Also, confirm the ssd size?  Is it 64GB or more like 250GB?
Mpothoven82
Old is a Transcend 64Gb Sata M2 and thr new one a 250Gb nvme M2
AlHill
In your third pic, uncheck legacy boot priority.
If this does not help, @LeonWaksman may be able to help, as I do not have that NUC.
Mpothoven82
It won’t boot when I do that
Mpothoven82
This is what I see.
I get the feeling this ssd isn’t supported
AlHill
When you use F10 to select a boot device, are you selecting the usb stick UEFI mode?
Mpothoven82
Screen blinks and nothing happens, doesn’t boot.
If I just boot it does go to Windows setup, but when disabling legacy it doesn’t boot at all.
Mpothoven82
Anoying I can’t edit my post.
What I mean is in the F10 menu I see the USB but when I select it the screen blinks and it goes back to the menu
AlHill
I am going to defer to @LeonWaksman  He is the wizard on these nucs!
LeonWaksman
Hi @Mpothoven82  and @AlHill
Checking at Technical Product Specification, para TABLE 1 (page 11) and para. 2.2.3.2 (page 47),it's looks to me that your NUC5i3RYK, equipped with I3-5010U CPU (your NUC) doesn't supports NVMe SSD. While NUC5i3RYK equipped with I3-5005U CPU supports such SSD (only with limited performance). So, I thing in your case you need to buy SATA SSD or, newer generation NUC.
I for my self, don't have NUC RY to verify this, but this is my understanding while I'm reading the TPS.
Leon
Mpothoven82
But it does recognize it in the bios, it had the option for nvme.
Expansion Options
PCI Express Revision
Gen2
PCI Express Configurations ‡
M.2 slot with PCIe x4 lanes
M.2 Card Slot (storage)
22x42/60/80
https://ark.intel.com/content/www/us/en/ark/products/83256/intel-nuc-kit-nuc5i3ryk.html
Mpothoven82
@ LeonWaksman
LeonWaksman
Hi @Mpothoven82
I'm taking back what I wrote in may previous post. For me the description in TPS is misleading. From the following post  that your NUC supports the NVMe drive. Since I can't verify this, I suggest that you wait for the official Intel answer from Intel. This will probably happen not before Monday.
Leon
