Intel® NUCs
Assistance in Intel® NUC products
12978 Discussions
Laptop X15, NUC Software Studio, and Color Calibration
MDS1
LAPKC71F is my official model number- I'm using NUC software studio 1.21.17111.0
The "Display" settings section of software applies a custom color profile/overlay to both
the laptop main display and any other external monitors.  Here are my issues:
*"Standard" setting is not neutral/off- it jacks up the gamma on both monitors
*"Custom" I can use to get desired calibration, but this is sometimes overwritten by windows applying other calibration settings when I go into windows display settings
*"Custom" settings apply to both laptop display and external monitors- if I get it right for one, it's not right for the other.
*Calibrating using windows calibration or 3rd party software is overwritten when launching or using NUC software studio.
Bottom line is, I can't obtain and maintain a proper color profile.
Is there any way to disable this display setting functionality? I'm glad to edit registry, whatever it takes.  Thanks in advance.
Jean_Intel
Hello @MDS1
Thanks for posting into the Intel communities
I would like to confirm some information, just to have a better understanding of your issue, please provide me with the following:
Looking forward to hearing from you.
Jean O.
MDS1
Thank you for your follow up.
  • Present since day 1, yes
  • No major changes
  • Is the nuc software studio service applicable to my model?  I am used to using uniwill to support the software studio package.
    • In any event, I do not see any changes after installing
To be clear this is a branded XPG Xenia 15 KC, essentially a LAPKC71F with adata branded ssd and ram.
Jean_Intel
Thanks for your response.
I noticed that your unit is not on the list for supported products for the Intel® NUC Software Studio Shows, which may explain why the software has been having issues since day 1. The compatible product list is the following:
  • Intel® NUC M15 Laptop Kit - LAPBC510
  • Intel® NUC M15 Laptop Kit - LAPBC710
  • Intel® NUC 11 Enthusiast kit - NUC11PHKi7C
  • Intel® NUC 11 Enthusiast mini pc - NUC11PHKi7CAA
  • Intel® NUC 11 Performance kit/mini pc - NUC11PAxix
I hope you find this information useful. Let me know if you have any questions regarding your issue.
Jean O.
Jean_Intel
Hello @MDS1
Hope you are doing fine
Jean O.
sharpjd
Hi... I'm replying yet again to another long dead post but I've found that ColorSustainer was a good workaround for this issue in my experience. The interface is slightly convoluted and I don't remember the default config so you'll have to play around with options, but associate monitors you don't want to apply the Nuc Software Studio color settings to with the "LINEAR" color profile.
Edit: Upon opening the interface, click "Detect" and it'll list all the monitors connected to the device. By default, it'll give you a whole bunch of resolutions you can associate certain color profiles with for each monitor. But if you right click them it'll give you the option "Change to Global" — click this and it'll associate color profiles with the monitor regardless of resolution (I recommend doing this).
I guess you could also set this app to run on start, use Task Scheduler, or cmd shortcuts to make this solution a little more elegant. The app supports the command-line parameters -start and -hide to automatically start the process and hide it in the system tray.
As a side perk, it'll also fix the annoying issue of some full-screen apps like games overriding your color profiles. Though this solution is not perfect (relies on polling intervals) and some games may override the color for brief moments
